Final Computer Parts List: Opinions Wanted
bikinpunk
G-g-g-g-g-unity!
Here's the final list unless I have any warnings:
Gigabyte GA-945GM-S2 Socket T (LGA 775) Intel 945G Micro ATX Intel Motherboard - Retail
Model #: GA-945GM-S2
Item #: N82E16813128016
In Stock
$96.99
XFX PVT42EUDE3 Geforce 6800 XTreme 256MB GDDR3 PCI Express x16 Video Card - Retail
Model #: PVT42EUDE3
Item #: N82E16814150130
In Stock
Mail-in Rebate
$137.77 -$35= $132
Thermaltake TR2 W0070 ATX 430W Power Supply - Retail
Model #: W0070
Item #: N82E16817153023
In Stock
Mail-in Rebate
$39.99 - $10= $29.99
Intel Core 2 Duo E6300 Conroe 1066MHz FSB LGA 775 Processor Model BX80557E6300 - Retail
Model #: BX80557E6300
Item #: N82E16819115005
In Stock
$218.99
Kingston ValueRAM 1GB (2 x 512MB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Unbuffered Dual Channel Kit System Memory Model KVR667D2N5K2/1G - Retail
Model #: KVR667D2N5K2/1G
Item #: N82E16820144199
In Stock
$85.99
Subtotal: $579.73-(35+10)= 534.83
Whew! Let me know if there's any concerns. I'll likely be ordering tomorrow afternoon.
Edit: The power supply size has been brought to my attention. If anyone knows of a microATX Power Supply that does at least 450w, please let me know.
I'm not here to argue Processors. From 2 different computer forums and 1 other sound forum many people who owned AMD x2 processors suggested the duo core 2. If I go back to processors my head is going to explode!
the intel duo is better then the AMD dont let any jackass tell you different.
If you are buying you processer retail you shouldnt need a aftermarker heatsink the OEM one will be fine unless your going to be overclosing or whatever.
On advice of you guys I changed the PSU. The size is identical to what I have in my computer now. Let me know what you think.
$96.99
Model #: PVT42EUDE3
Mail-in Rebate
$137.77
SPARKLE FSP550PLG-SLI ATX12V/ EPS12V 550W Power Supply - OEM
Model #: FSP550PLG
Item #: N82E16817103517
$109.99 -$20.00 Instant $89.99
$218.99
$85.99
Subtotal: $629.73
Price after MIR:
$629-($10+$35)=$584.73
Well, looks like I'm going to be scratching off my list completely. Went to a shop today and the guy said that I can't use a conventional microATX mobo in my tower, we tried. I think I'm just going to scrap everything and start all over. Not even use the parts from my computer that might be good. The chances of my HDD & optical drives surviving are slim. However, they will be tested in a new unit before the new optical & HDD are put in. If the old ones work, then I'll send the new ones back. Just going to get everything I might need in case.
Should I start a new post on a complete computer build, or continue here? //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
This is a tentative list. I'm not sure about the mobo, but I think it will work. I was hoping to stay under $650 for everything. If you guys see anything that could be toned down a notch let me know.
Remember, I'm doing no gaming. However, I will be doing some moderate video editing in the future.
COOLER MASTER Centurion 5 CAC-T05-UW Black Aluminum Bezel, SECC ATX Mid Tower Computer Case - Retail
Model #: CAC-T05-UW
Item #: N82E16811119068
$49.99 $49.99
Gigabyte GA-945P-S3 Socket T (LGA 775) Intel 945P ATX Intel Motherboard - Retail
Model #: GA-945P-S3
Item #: N82E16813128015
In Stock
$92.99 $92.99
Model #: PVT42EUDE3
In Stock
Mail-in Rebate
$137.77 $137.77
Antec TRUEPOWERII TPII-550 ATX12V 550W Power Supply - Retail
Model #: TPII-550
Item #: N82E16817103931
In Stock
$89.99 -$5.00 Instant $84.99
** This item is warranted through the product manufacturer only. what's this?
In Stock
$203.00 $203.00
Kingston ValueRAM 1GB 240-Pin DDR2 SDRAM DDR2 533 (PC2 4200) Unbuffered System Memory Model KVR533D2N4/1G - Retail
Model #: KVR533D2N4/1G
Item #: N82E16820144151
In Stock
$82.99 $82.99
Western Digital Caviar SE16 WD2500KS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Model #: WD2500KS
Item #: N82E16822144701
** This item may only be returned for a replacement of the same make/model within 30 days only. what's this?
In Stock
Mail-in Rebate
$77.99 $77.99
SAMSUNG 16X DVD±R DVD Burner With 5X DVD-RAM Write and LightScribe Black ATA/ATAPI Model SH-S162L - OEM
Model #: SH-S162L
Item #: N82E16827151118
In Stock
$31.99 $31.99
Subtotal: $761.71-$45 in Rebates= $716.71
I'm thinking about getting this case: it comes with 450w PSU, which is recommended by the graphics card I've chosen (thanks Jmac for the recommendations, I just can't afford to get the 7600 cards, I looked at a bunch). Now, will giving exactly 450w be sufficient? Or do I NEED to go higher?
Antec Sonata II
http://www.newegg.com/Product/Product.asp?Item=N82E16811129155
I'm also looking at this firewire/usb add-on. Is there a way I can use this to take advantage of the front usb/1394 ports on the front of the Antec case?
http://www.newegg.com/product/product.asp?item=N82E16815106004
bikinpunk
G-g-g-g-g-unity!
bikinpunk
Alabama
Megalomaniac
