fiberglassing inside box
frogcase2002
alright, just finished building a box inside my trunk for my zcon 15, its 4.4 after port dis. tuned to 32 and now im wanting to fiberglass the inside, but never have done it so im seeing if anyone has any tips or anything good to do, i have some fiberglass cloth and mat and got the resin , any ideas,, should i put alot of the mat or something in all corners and resin over to kinda round off the corners?
are you chasing tenths? if not no real reason unless your box is flimsy. Personally I'd just 45 the corners instead of fiberglassing.. much more easy
What he said
fiberglass is a waste of time to me...unless your strictly competing. If the box is built good enough and braced you don't really need it. Seal the edges with silicone and be done with it
im just wanting it as strong as it can be and i had to build the box inside the trunk with only a inch or 2 inbetween the box and trunk so i had to use a tiny drill bit and wrench to screw all the screws in(******), so im sure its not as strong as it could be, and i have all the **** to fiberglass,
when fiberglassing the inside should i just line the whole inside of the box with mat and cover it all up with the resin,,,, maybe more on the corners?
Putting fiberglass on just the wood is going to do you nothing. What you want to strengthen is the joints. Put a coat of resin on the joints, cut some mat maybe 3-4" tall and however wide you need it. After you have the first coat down, press the mat into the corner with your paint brush, then apply another coat of resin, making sure to keep the mat as pressed to the wood as you can.
frogcase2002
frogcase2002
hamilton, ohio
mlstrass
    Jun 24, 2026
    Jun 24, 2026
