Fiberglassing didn't go so well... help.
you could also try to work without gloves, it wont stick to ur skin.....
i never do glass work with gloves or anything on just wash ur hands when ur done with laquer thinner and they wont be sticky anymore
i think your biggest problem is that you are trying to lay this glass upside down while its soaking wet.
you need to use the least amount of resin as possible. and also another tip - get like a 2" chip brush from the store, and cut the bristles down like 1\2 way so they are stiffer. this helps poke the bubbles out.
so when you lay this glass, you need to rip a bunch of pieces of your fiberglass, then coat the surface lightly so the glass sticks, and put your pieces down. then using as little resin as possible, poke and prod the glass until it soaks through while working the glass with a stippling technique.
not to mention mekp burns your skin //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Man fark that chit. Women waxing their legs looks painful enough. I sure as hell don't need to wax my hairy ass arms lol //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
meh ive never had a problem and did numerous glassing projects.... **** doesnt even make me itchy like people complain about. i dunno all peoples skins are different, mine usally does not get irritated verry easily by chemicals or other outside eliments
I think we have a winner! I'm going to try this technique with the last couple tubes I have of hardener, I'll make smaller batches though.
I read that I should do all the layers at once and it would be easier. I don't think that applies to what I'm doing though, the third layer didn't stick at all.
I have some cloth mat as well, I was going to use it for a rear deck cover, but I'll do anything to make fiberglassing this box work better.
It is better ( especially in cooler weather) to do as many layers at a time as you can manage. It helps hold heat, for a better, quicker cure. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thank you, I did check the ground and and fuse holder wires and everthing is fine. All I did was swap amps and the previous Alpine pdx sounded...
81
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
588
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
578
sexiewasd
sexiewasd
Maine
THUMPPER
