Fiberglass wall
  • 5
yea... if your clueless on how to do a wall... pay someone to do it... not the same as building a regular box in anyway at all... but if you want to do it yourself, research through the build logs on here, and try to learn as much as you can
In most cases the fiberglass that covers the wall is just a "trim panel" or sorts.
agreed... if your looking to straight up fiberglass a wall... your talking about a SHIT TON of glass, and even then, you'd have alot of flex issues... mdf or birch is the way to go
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
4K
No reason you couldn't just glue a ring of plywood up under there then paint it with some bedliner or plasti-dip or similar to keep the elements...
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
What would you recommend using for the roof then ? Should I do just the bpillar or the whole roof ?
917
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
2radar
2radar
tallahassee
mast240
Decebal
    Jun 10, 2024
