fiberglass strength question
RiceNotNice
la
Ok-kind of an odd question but.....I'm building a fiberglass enclosure in my spare tire well. The problem is that i've forgotten how many layers i've layed (**** fumes!). I'm guessing it's around 2 layers of cloth and probably 4 layers of mat, again guessing. I took the thing out and stood on it without falling through (good sign). Is there any way to tell when an enclosue is strong enough. It's only for 1 sub recieving about 350 watts. **** Fumes! //content.invisioncic.com/y282845/emoticons/wacky.gif.cf4a48f9e6dfe9504ffd2c946fd2f340.gif
im assuming, especially since you can stand on it, its probaby strong enough. You should just check for soft spots or spots especially on the more vertical sides where resin could have ran off the the bottom and left thin layers.
6 layers should be plenty for that enclosure.
If you stood on it, you should be fine. Check it over a couple times and see if there are places that could use a little more.
- Steve
RiceNotNice
RiceNotNice
la
ss3079
