Fiberglass Enclosure Help!
  • 3
Mark_ab
The Alpha Male
I'm really wanting to dabble in fiberglass enclosures. I've been rooting around on the internet, and haven't found anything to fit my need. I'd like it to be attractive, as the box isn't merely fitting in an awkward spot (such as a wheel well) so it sits flush. I'm sure most of you have seen show cars with the contoured sub boxes. This is what I'd like to do, however, I dont' know the best way of going about it. I know how to do the painting etc so no need for help there.
http://www.mcmullenargus.com/gallery/view.asp?image=31890&pub=9
This isn't how I'd like my subs aligned, however, the fiberglas is how I'd like mine to look.
http://www.mcmullenargus.com/gallery/view.asp?image=30281&pub=9
There's another.
Audiolife, perhaps?
Thanks for the help
It's not all that difficult. It just takes time, a little patience, and a bunch of sanding. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Here is a link to a thread on carsound. http://www.carsound.com/ubb/ultimatebb.php?ubb=get_topic;f=4;t=002367#000018 pictures and pretty good instructions as well. Just remember to take your time and wear gloves //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
4K
No reason you couldn't just glue a ring of plywood up under there then paint it with some bedliner or plasti-dip or similar to keep the elements...
6
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
681
Mark_ab
The Alpha Male
Mark_ab
Edmonton, Alberta
MikeofTulsa
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
