fiberglass enclosure: 12" or 2x 10" shallow mount subs?
  • 1
Rsx_03
LoW aNd sLoW
347
miami
i finally decided to make use of my fiberglass mold i did of my spare tire well
it has about 3.2 cu and is about 7" high, sub perfect for a shallow mount
but i cant use all of the 3.2 because i have to make a pocket for my amp's. so about 2.7 im estimating
ive looked at cvt and pioneer but i cant find a 12" shallow sub that can handle about 600+ rms.
could i fit 2x 10" ported instead?
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
4K
No reason you couldn't just glue a ring of plywood up under there then paint it with some bedliner or plasti-dip or similar to keep the elements...
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
693
Rsx_03
LoW aNd sLoW
Rsx_03
miami
Rsx_03
    May 16, 2024
    May 16, 2024
