ole_gators
Hello everyone. I'm in the process of building a small budget system and I want to get the Fi X 12" as my sub in a sealed enclosure. It will get power from Crescendo 1000C4(~500W bridged). I know that the recommended enclosure size ranges from 0.6-1.1 cuft but I don't know if I should go with a larger(1.158 cu ft.) sealed box or a smaller one(0.749 cu ft.). Both boxes are pre fab from sonicelectronix. I listen to dubstep, rap(eminem) and rock. I want the sub to have good amount of output and produce good lows. So which enclosure is right for me? Also, how would the Fi X Series 12" compare to Image Dynamics IDQ12 V3? Will I be able to hear a difference between these two subs assuming both are in recommended enclosures? IDQ gets recommended a lot for sealed enclosures but it costs a bit more than I want to spend. Are there any other subs in $150-180(shipped) range that work well in sealed enclosures? Thanks in advance!
