Fi Q not hitting
what was ur crossover at? did u set ur gain with it at that?, that will blow some of the subs frequency range. somethin that happened when i had my cheap LA 12" sub. i had lpf at 50 hz set gain with 50 hz -6 db tone, sub hit good then didn't hit as good as days went by, like it got weaker and weaker, everything up from 60 hz it still played.
I've have a kx and the subsonic filter switch is only on/off but I think its factory default at 25 and x-over was at around 70
Also why do you think I couldn't get any readings off the volt meter while trying to set the gains I'm sure i did it right
yeah I did that but still nothing must I could get out of it was like up too 5 volts and I know I did it right bc after that I did my friends who was helping me and it actually worked ACv at 200 is what we used
squid88
squid88
North Carolina
luvinthebass
