Fi Q 15"
my badd:
Q15
DUAL 1 | DUAL 2
Fs: 25.9 Hz | 24.9 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 5.64 | 5.72
Qes: .54 | .54
Qts: .49 | .49
Mms: 257g | 279g
Cms: 0.15mm/N | 0.15mm/N
Sd: 810cm^2 | 810cm^2
Vas: 135 l | 135 l
Spl: 88.2dB 1W/1m | 87.7dB 1W/1m
Bl: 10.4 N/A | 15.1 N/A
Xmax: 27mm
Rms: 1000W
Sealed box: 2-2.6 cuft
Ported box: 2.8-4 cuft @ 28-33Hz
Sub OD: 15.625”
Cut ID: 14.125”
Mounting depth: 8.500”
Displacement: 0.19cuft
Product code: 01715
Also, I have heard nothing but good things about their subs, but I don't know if I can trust a company that's only dedicated to online sales........
You can trust the company too. Theres an interview with the owner on here somewhere(don't know where). Sounds like a really good guy and takes exceedingly large ammounts of pride in his company and his product.
You all are talking to guy guy who has done dozens of HU/Amp/Sub installs but this will only be the second box I am about to make, and the first had the recommended port size with it.
Qbenjamin
Qbenjamin
Braavos
jeremiah
michigan born
    May 14, 2026
michigan born
    May 14, 2026
