Fi BL 18" box size
I think you should sell me one of them.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
But honestly, what options are you going to run on them?
The last BL I had really liked the bigger box I put it in, so if you have more room, I'd go for bigger.
7 cubes is PLENTY for each 18. i have mine in 5 and it sounds smooth and gets low
Ok. I'm going for more lows in the system. In my finding a larger box helps out with the lows.
mines a differant subbut 18s dont always need 10cubes to get loud
Ya, if they did it would be time for a wall //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I had my Bl 18's in a 11 cu/ft box and a 14.2 cu/ft net box. The 14.2 cu/ft box had a flatter response and yeilded the best score. Same vehicle with both boxes. Both tuned to 30hz.. You will be just fine with 14 cu/ft net for the pair.
yes. larger boxs on lower power sound better and lower. if u add power to that box though it will get stinky faster so take that into account. are you going to upgrade the amp anytime soon?
Hell no. No money. If I upgrade the amps, best believe there will be a new sub stage.
Buck
little alien on campus
Buck
Inside of a pyramid
Buck
