FI audio.
m4i2k2e2
this is my chin bank
333
ma
ok, i have been look at FI audio. i have a zx750.1 putting out 930wrms. i was thinking about ssd12. as of now i have a 12" L7, in a ported box 2.5 cubic feet, tuned at 35Hz. now the L7 gets freaking loud. but, its get very distorted with some notes.
1. will the ssd be as loud or off by much?
2. how will the sound quailty compare to the L7 if put in the recommended ported box?
if your L7 is distorting something is not set right. properly set your gains, and turn off all bass boost. if you hear distortion your amp is clipping and that is not good
since someone is bound to do it, what is fi's website?
its distortion on certain notes. like, the song i wanna **** you. shoot em up, how we do. idk, certain notes in songs do it. like, higher pitched notes.
whats the x- over freq. do on my amp?
it cuts off frequencies below a certain point. that should be no higher then 80 hz. there is good amp setting information in the amplifier forum or on http://www.caraudiojunkyard.com i suggest you read up and reset your amp cause it doesn't sound like you set it up good.
How do you figure?
One of my friends just got his 12" SSD, and to me, it sounds a lot better than the L7 i heard. Both in sealed boxes, however. The L7 was louder to me, but the SSD just sounded clearer.
Ported could be a whole different story.
If i read correctly he has a ported box, so the statement about the sealed box is useless. Also l7s are not ment to be ran sealed. His problem is not the woofer its self, but the install.
my ssd is louder than my L5's were if that helps
i put L7's to shame. and sound alot cleaner doing it.
ported.
If you get an ssd, get the flatwind coil for alittle extra power handling. If you want a 10, im selling mine. 20 min of play time on about 950w
m4i2k2e2
m4i2k2e2
ma
billabongcr
