Fi Audio Neo's are back!!!!
Yeah, those are gross. No thanks. I like these better, I haven't talked to the guy I sold them to in a while:
I just want those amps //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I still have the Ampere 125.4 in my truck. It's not in great cosmetic shape anymore //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
I traded the M4a plus cash for a Taramps 20.2kw
down here its often 120-130 degrees in the car with the AC off. amount that with burping 10-15k and doing demos it gets hot as ****. ill find the thread. i'm just not going to go out my way when i've tested the neos in similar applications and the field strength went down pretty drastically.
i'm not saying all neo motors do suffer from this but ill bet you never measured as well. like i said in the induction motors i built they had alot of problems. hence why you dont see many of them on the market..
i put up several links to show how they preform in applications where high heat is a factor but you refuse to even read it..
Ok. It's this simple get a decent military meter with a thermal couple put it on the magnet and see what the tempature is..
Or you can measure the large signal parameters when the coil is hot and measure the qes shift. I'm putting my money into doing other things not going around looking to see who has poor designs.
els1989
els1989
Minnesota
mazdakid
