Fi 15" Q Box *Pics*
kicker06
Umm, I don't pay for food
Does this all look correct for a 15" Q on ~1200w?
Can someone just look over everything and make sure it's all good? The port looks weird, since it's weird, but that's what RE said =\
The build will start soon, the sub will be here by the end of the week.
Yall are loving some 12-16 sq. in. of port per cu. ft. lately. Id just not add the port length on. I wont even change tuning hardly I doubt. Im not a big fan of bracing myself, but if you feel like you should Id just put a piece behind the sub and hope it doesnt mess with the port.
The box looks good.
FYI,
The actual specs calculated with driver displacment of .19 cu/ft =
Net Volume: 3.77 cu/ft
Tuning Freq: 33.69 Hz
I'll repost this...
I will be running a 15" Fi Q on a 1200wrms in my trunk car, with sub facing UP and Port Backwards. I want 4.0 cubic feet after port and sub disp, tuned to 32hz w/ 65sq" of port.
I want the box to be 30" long and 14" high, my max width is 30" though.
Here is what I came up with so far, but I cannot figure out the second port length for the correct tuning.
External Dims: 24"w x 30"d x 14"h
Internal Dims (using .75" wood) : 22.5w x 28.5d x 12.5h
Internal Volume includ. port disp = 4.638
Port 1 = 5.25" w x 12.5" h x 24" d
Port 1 disp = 0.9
Port 2 = 5.25" w x 12.5" x
And that is where I got stuck.
I need the depth and height to be the same, but the width can be changed around.
kicker06
kicker06
Atlanta & South Carolina
kicker06
