Stinger23
Overview:
I installed a system in my boat. It's a Pioneer DEH390MP HU, 12" RF sub in a bandpass box, four 6.5" Polk DB651's, and two 8" Bazooka wakeboard tower speakers. I've got 3 amps total. One is running the sub, one for the tower speakers, one for the 6.5's.
Grounds:
I'm running a secondary battery just for the stereo and a battery isolator keeping it from draining the main battery. HU is grounded through the fuse panel in the back of the dash, all the amps are grounded to the secondary battery. Secondary battery is grounded to the main battery which is grounded to the engine (the only place to ground on a fiberglass boat).
Power Wires:
All amp power is coming from the secondary battery. HU power is in the factory dash wiring. HU has 3 preamp outputs which of course are hooked up to the amps via rca cables.
Problem:
If ANYTHING is running besides the stereo, it creates an extremely loud buzzing/humming sound through the speakers. The volume of the noise does not change if you turn the volume down on the head unit. Each accessory that runs causes a slightly different noise (bilge pump, depth finder, engine, etc.). The sound will change when the engine is revved. Also if you turn on any lights in the boat, there is a loud "click" through the speakers when you flip the light switch on.
To troubleshoot this problem I have:
1) ran a ground directly from the stereo battery to the engine (bypassing the main battery)--no change
2) double checked all connections, disconnected, reconnected everything--no change
3) move all power wires away from rca's, move rca's away from each other--no change
4) disconnected all RCA's--noise goes away
5) hooked one speaker to the speaker wire output on the stereo (bypassing the preamp outputs)--noise goes away
6) hooked up one amp with rca's--noise comes back
7) tried hooking up just any one amp and any one rca cable (every amp/cable/output combo was tried)--noise is still present.
I'm about ready to throw this $1000 system in the trash and start over, I just can't figure it out. Any ideas would be welcome. Thanks.
Grounds:
Power Wires:
Problem:
