Southwest Region February 18, 2012, MECA comp - 17219 N. 19th Avenue, Phoenix, AZ 85023
AZ,CA,NM,NV,UT
  • 2
possibly. I did a 148.6 in the kick unofficially... just need to do some interior tweeking.
Seal that trunk up yo. Let's build a box for my hcca152 sub and install it in ur trunk an see what what happens with one of those 6500 watt soundstream amps hooked up to it!!!
too much trouble to put that big *** ORION in my car. however. I will not write off that idea...
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
684
Try crutchfield.com and use the application that gives you replacement options for system components. I ripped out the entire system in my Mustang...
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
Nice, much better looking version Ford than its American counterpart. Go down to the local stereo shop and tell them you want to the work yourself...
subzero
subzero
Chandler, AZ
520reaudiosx15s
    May 19, 2024
    May 18, 2024
