fbi90909's TC LMS 5400 15 + Saz3000D rebuild + fiberglass
don't know nor do i give a shit what you said, but stay out of my build thread. act a faggot elsewhere.
uploading pics now
Lol ragged......
VV read the quote below.
well since the first sub beauty panel wouldn't work when the sub was in and my frustration going over me to a point where i damaged the panel up pretty bad i ended up setting myself back to having to restart the beauty panel again. this time i had to di it from a different approach. the first one was made so that the sub would "pinch" the panel in place but in reality if didn't want to.
so in hopes to get the panel to sit in place i cut the flat trim that was supposed to be sandwiched in place and attempted to slip it over the sub. after a good hour and a half of trying to get in it place i took my rage out on it.
so i took a break and set the build aside as i needed to think of a way that i can reate a beauty panel that will slip over he sub that isn't permanent. the reason why i can't perma mount the beauty panel is if i ever need to access my coilovers i would be able to with a removable panel.
so what i came up with was to make a sub ring that was set as the size of the outer edge of the speaker. then i'll temp mount the ring onto the box, then fleece it, then remove it. with a ring set, i could then slip that over the sub when mounted.
overall that is what was done this week. i had work this whole week so it pretty much took me all week.
i'll explain as i go.
taped surround so i can mark the placement of the speaker on the enclosure
clearance that may be an issue for the new ring
marked
sub removed
damage to the enclosure from mounting the sub the first time.
exact outer diameter of the sub surround.
jiggy wit it
you can't really see it but the sub top assembly is IN the cut hole for testing. needs a little sanding but it's a snug fit.
mounted the top assembly back in place
test fitting the ring i know the outer area of the ring isn't perfect nor pretty but i could careless. it's a portion that won't be visible to anyone. plus i just wanted to cut the ring out lol. OHH!!! i forgot to mention. the ring was made out of 1/2" MDF
this was a tricky area. i had to sand the top portion of the ring to be thin so when the sub was actually mounted it still has enough clearance to slip over and between the rear dash.
//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
so my idea of mounting the ring was to add a mass amount of hot glue to the back of the ring. i predrilled and mounted 4 screws onto the ring so they can clamp the ring in place to allow the hot glue to cool down.
first after i set the hot glue i let it all cool down.
with the hot glue hardened i began to run the screws to at least hold the ring in place. with it in place i took my heat gun and began heating the ring one section at a time to melt the hot glue then tighten down the screw to clamp the ring down.
first section melted and screwed in place
second area and so forth
here i clamped the bottom cause it needed a little support
with the ring done it's time for fleece prepping
i'm typing up the second batch of pics now lol.
alright with the glue and the car cooled and the car prepped with tape it was time to start fleecing. i didn't take a pic but here is the ring in plave before i removed the screws.
starting to stretch
after the starting of the stretch i took the basket once again and clamped it into place to pull the fleece into the trim ring
since some of the area of the fleece wasn't making contact with the ring i had to crazy glue it in place
resin it up and ready for glassing. i had to use bondo again. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
glassin it
after i was gone glassing i had to get the basket out before i could pull the trim out. i had to "chisel" it out to break off the excess FG that got onto the basket. **** that was tedious.
cleared out
fleece trimmed to allow access for heat gun
heat gunned and removed. it came off pretty easy after like 5 minutes of heating it all up and tugging a bit
ready for trimming
fleece cut
i then took some 5minute 2part epoxy and spread a bead along the joining of the fleece and the trim ring. why? cause i just want to make sure that the ring won't come off while i'm adding filler or sanding being that the ring is really only held on by a little bead of crazy glue.
bead set
while the glue was setting it was time for some clean up
cleaned up the hot glue
cleanup for ring
done
took the dremel and trimmed off the excess glass around the edges and prepped it for glassing for further trim. lol.
panel set in place
a little tape added and a clamp just to be safe so it doesn't come off while i'm glassing
glassing the trim
pulled. i gotta tell ya, using paste wax is the shit!, it literally took me 15 seconds to pry off the panel.
trimmed up and washed down. using the heat gun to remove any excess moisture prior to add body filler
filler spread and sanded.
uploading third batch now
fbi90909
Panty Thief
fbi90909
Key West, FL
Annnarbor84
