Justin89T
I Drive A Supra
Yeah, or you can fire right into the amp. Should work just fine. I don't have the color codes and you can't test them, but if you can find the diagram online you should be set.ya justin....thats exactly what it is.I knew I could count on yall.So if i can get to the other side of the amp,disconnect it and use those wires,(speaker wires) I should be good right?
Or grab the plug he cut off and go buy a metra part number 5511 harness. That'll give you the pin out you need.
