fart box design
thormxkid
hey im looking into build a budget fart box...
i'll be running a 12 type r and a 500/1 for power.
im just looking to spl the box not listen to it on music.
it'll be goin in a 2003 grand am. thinking of doing a external port.
what would be my best options to get this thing box wise?
size and tuning
I vote 2 cubes after displacements with 6" or maybe try even an 8" aero. CRX style //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
in 2 cubes a full length 8" aero (18") would be right around 53hz. Would be obnoxious (loud)
so i ended up makin a box little smaller then planned it 15x15x18.5...it was all i could make with the wood i had...so 1.75 should be the total size if i figured it out right...i'll me mounting the sub inverted for more space in the box....now i all i have is 3 inch pvc for ports how could i use this instead of one 8inch peice...i can't seem to find a calutor to figure it out? any ideas on lenght and how many pieces?
idea of a burp box is to reach the max limits and output of the sub so i would have gone 2.5 cubes tuned to 50 with that power. less power equals bigger box. 2.5 cubes will give u alot of output and for daily would not be that great but for spl it would have alot of output and put up decent 40s for numbers
k but my box is 1.75 now i might build a new one in the future but...if i wanted to tune it 50-56 hz range how long would the 3 inch pvc need to be and how many should i run?
Four 3" ports cut to 15" long tunes to 50hz (or a bit under) Start there and you can cut down an inch at a time if you need to tune higher. I'm assuming you want max port area. You could do more if you don't mind longer ports.
Download winisd (it's free) it'll allow you to calculate volume/port/tuning etc.
thormxkid
thormxkid
ontario
thormxkid
vegang
vegang
