Factory and Aftermarket H/U
Goldenknob
Bored In Antlers
What is required to have a factory and aftermarket headunit both installed? My Ex wants to me to install a spare cd deck that I have into her car. she currently has the factory unit, only a tape and radio deck, in and dosn't want it taken out. Do I need any sort of signal converter or anything to have both hooked up.. would I just splice all the wires together? she dosn't have anything fancy everything is factory in her car. there is no sense in telling her to change any of it because she would just rather not have a cd player if it's going to cost money (a real penny pincher). anyone have any recommendations?
ok.... as I stated... I am installing a headunit into her car that has a cd player.. along with her existing factory headunit with a tape player.. so she can have the best of both worlds... she isn't a audio fanatic.
It is much Much MUCH more trouble that it's worth to try and run two head units to the same speaker sets. No, you CAN'T just splice all the wires together unless you want to fry them both. What kind of car is this?
this is a ford thunderbird. a 92? or something in the 90's model. she uses her tape player.. that's why she wants to keep it in... she won't use both at the same time, obviously.
The previous poster suggesting using a portable CD player with the tape deck converter probably had the most practical idea. If your wife isn't an audiophile, why bother with a horribly complicated install?
here you are... now can you help? //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
no portables.. I'd like this install to look and work decent I know I could just splice the speaker wires together or just run another set to the speakers... the only thing is that she would have to make sure only one was on at a time.
Nice if it was that easy. Unfortunately, if two different outputs are wired up to one set of speakers, then the output that is playing will be sending voltage directly into the output that isn't playing, as well as to the speakers. Chances are the first one you play will be the last one you play.
You can do it by using 4PDT relays, activated by the aftermarket head unit's remote output, and wired so that they switch the speaker connections from the old head unit to the new head unit when it's powered on. Way more trouble than it's worth, IMO.
If your new head unit has an aux input, I suppose you could use the old head unit as an aux source with a line-out converter.
Goldenknob
Bored In Antlers
Goldenknob
Antlers, Ok
KaeZoo
