kc_f150
Hi all,
I received a pionner TS-W254C 10" subwoofer from a friend, and I was thinking on creating an vented enclosure for it and installing it under the rear seat of my 06 F150 supercrew. However, the speaker's hight is 6" and I don't know if an enclosure with a 7" mounting depth will be good enough. I don't think I can build an enclosure with a mounting depth bigger thant 7" because the enclouse will not fit under the seat. Has anyone had any success installing a subwoofer this tall without lifting the seat? Please help!
Thanks!
SUBWOOFER SPECS
Rec. Sealed Box Dims: 0.80 - 0.80 cu. ft.
Rec. Ported Box Dims: 0.90 - 0.90 cu. ft.
Free Air Usage: not recommended
Sensitivity: 87 dB
Frequency Response: 18-2,500 Hz
Recommended RMS Power: 250W
Peak Power Handling: 500W
Impedance: 4 ohms subwoofer wiring options
Thanks!
SUBWOOFER SPECS
Sensitivity: 87 dB
