Sold F/S: USED Soundstream TR-1600/2 $300 shipped.
BryanCain
Banned
Very good amp. Amazing sound quality. Only got a chance to use this for 2 weeks //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
$300 shipped.
What trades are you looking for?
Well, after sitting on here for 3 days looking at nothing but car audio products, I've decided to buy a wagon and build something based around my Van Gogh, TRA680.4, and Alpine CDA9835...
What do you got for me that would match that?
RUBI™ (Rapid-Use Branched Impulse) Proprietary power supply topology
STACT™ (STabilized Apex Current Topology) Reduces power supply stress by 50%
Trident™ Amplifier protection topology
Tone Sweep Calibration Optimizes the power supply to the connected speaker load
Hawkins Bass Control™ Proprietary bass equalization topology
Continuously variable 12dB low-pass crossover (30Hz to 4kHz)
Three Stage Input Level Indicators
Output Clip Indicators
IDI™ (Intelligent Distress Indicator) gives visual amplifier protection status
Large Mouth Bass remote gain control
Continuously variable phase alignment (0° - 180°)
Vortex induction fan for thermal management
Differentially Balanced RCA Input
Fully Balanced 6-pin DIN Input
RCA Line Output
Gold plated 1/0 gauge power inputs
Harmonic Bass Alignment™ Produces tighter, more accurate bass reproduction
Discrete Balanced Class A Drive Boards maximizes linearity on low impedance loads
Drive Delay 2™ Eliminates turn on and turn off pops & noises
Chassisink™ Transistors are located between circuit board and heatsink for optimal heat dissipation
Power Grid™ Design optimizes current delivery to and from the power supply
20Hz – 500 Hz Frequency response
>115dB S/N ratio
>500 Damping
300mV – 5.0V Input sensitivity
0.02% THD
All Chrome Plated
# TR 700/2
# 2 X 175 RMS 4 Ohm
# 2 X 350 RMS 2 Ohm
# 1 X 700 RMS 4 Ohm Mono
# Dimensions 19.5" L X 4" H X 12.25" W
# TR 880/2
# 2 X 220 RMS 4 Ohm
# 2 X 440 RMS 2 Ohm
# 1 X 880 RMS 4 Ohm Mono
# TR 1600/2
# 2 X 400 RMS 4 Ohm
# 2 X 800 RMS 2 Ohm
# 1 X 1600 RMS 4 Ohm Mono
# Dimensions 30" L X 4" H X 12.25" W
# TR 500/4
# 4 X 125 RMS 4 Ohm
# 4 X 250 RMS 2 Ohm
# 2 X 500 RMS 4 Ohm
# Dimensions 24" L X 4" H X 12.25" W
# TR 800/5
# 4 X 50 RMS + 1 X 200 4 Ohm
# 4 X 100 RMS + 1 X 400 2 Ohm
# 2 X 200 + 1 X 400 RMS 4 Ohm
FEATURES: (TR 1760/D DIGITAL CLASS AMPLIFIER)
TST™ (Twin Stack Technology) Allows 2 amplifiers to drive one voice coil effectively doubling the power
Fully regulated, MOSFET power supply
PWM circuitry
High quality FR-4 circuit board
Satellite Power Gain (remote gain control)
Continuously variable 24dB low-pass crossover (50Hz to 150Hz)
Continuously variable 24dB subsonic filter (50Hz to 150Hz)
Variable 0 – 18dB subwoofer equalizer @ 40Hz
Tri-guard amplifier protection
Intelligent Distress indicator (IDI)
Platinum RCA input and output
Platinum 1/0 gauge power inputs
1-ohm stable
5Hz – 250Hz Frequency response
>80dB S/N ratio
0.30% THD
All Chrome Plated
# TR1760/D
# 1 X 440 RMS 4 Ohm
# 1 X 880 RMS 2 Ohm
# 1 X 1760 RMS 1 Ohm
BryanCain
Banned
BryanCain
Toledo, Ohio
SVT03L
