F/S Sundown 100.4
  • 2
thedukey42
Sundown 100.4
8/10 I've mounted it a couple times, so i'm sure it has marks around the screw holes. Other than its dusty, nothing else.
4/3/2 Channel Bridgeable Class-AB Amplifier
MOSFET PWM Power Supply
Stable Into 4 Ohms Bridged or 2 Ohms Stereo Load
Variable Subsonic Filter
Independent 1/2 and 3/4 Channel High Pass Filter Variable
with x 10 Range Selectable Switch
Independent 1/2 and 3/4 Channel Low Pass Filter Variable
HPF/FULL/LPF Selectable Switch
Independent 1/2 and 3/4 Channel Electronic Crossover Slope Selectable
Switch with 12dB and 24dB Octave
Variable Input Level Control
Input Sensitivity : 200mV ~ 6V
Subsonic Filter : 10Hz ~ 500Hz
Signal Input and Line Out RCA Connectors
Multi-Way Protection circuitry (Thermal/Over Current/Speaker Short/Speaker DC protection)
Tested Voltage & THD: 14.4V & Less than 0.05% THD
Operating Voltage : DC10V~16V Power Input
Wired Remote Controller
MSRP $549 USD
$250 shipped
[br][/br]
[br][/br]
[br][/br]
481
10
My wife is gonna sh!t bricks when my subs get here. She doesn't know yet
19
thedukey42
thedukey42
Cleveland, Ohio
thedukey42
    May 18, 2024
    May 18, 2024
