Old School Kenwood KAC921
kenwood kac 921 ......the amp works 100% and it sounds great. NEVER BEEN REPAIRED.
no scratchy gains. just loud bass....2 ohm stable. very underrated ..this amp will pound the crap out of some subs that are efficient. don't be fooled by its meager rating...
it can be used to run a couple sets of components.. it will absolutely scream. the sound quality is awsome. lots of headroom...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i would give the amp a 6 out of 10 for cosmetics.
it has some scratches and scuffs (normal wear).1 flimsy plastic guard around the positive terminal is missing. but it still works fine and tightens down..has all the speaker and power terminal screws..
for functionality i would give it a 10 out of a 10...everything works as it should..
has a built in thermal controlled fan, it only comes on when the amp hits a certain temp. stays off most of the time..
comes with a built low pass crossover with adjustable frequency..NO BASS BOOST! lol
i thought this was cool...you can give this bad boy up to 16 volts. i wonder how watts you could get out of it...//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
the manual http://: http://inform3.kenwoodusa.com/manuals%5Ckac921.pdf
specs:
2 x 180w max
1 x 360w max bridged
2 x 100W @ 4 ohms (0.3% THD, 20Hz - 20kHz)
1 x 200W @ 4 ohms bridged (0.3% THD, 20Hz - 20kHz)
S/N Ratio: 105 db
Freq. Response (-3db): 2Hz - 100kHz
Damping Factor (100Hz): >200
Fuse: 30A
Dimensions: 11.8" x 10.2" x 1.97
60.00 shipped to your door...in the cont usa...
this was the first amp i bought when i was younger. i hooked it up to a pair of MTX terminator 15's.. the 921 beat the crap out of those subs. sounded more like a 1000 watt amp.. i pissed off alot of 7-11 cashiers. rattle a bunch of windows around town... those were the dayz..
Item Pictures: i can get more pics if interested..
specs:
2 x 180w max
S/N Ratio: 105 db
Fuse: 30A
