F/S Old School Active Crossover BNIB
Louisiana_CRX
dem shoes......
Pyramid CR70 Electronic Crossover
This is an old school Pyramid CR70 2/3 way electronic crossover...with full night illumination...one neat thing about this crossover is the level controls have detents to precisely tune this...This was from Pyramids higher end line back in the day when they had amps made by PPI
I paid $99.99+tax from Coast to Coast back in the day....I'm looking for $70.00 shipped CONUS
FREE FREE FREE in CONUS
what kind of inputs/ outputs are on the back?
1 set input and low/mid/high outs?
and SQ wise its top notch?
mucho interested
It has one set of inputs and 3 sets of outputs...but can be ran two way or 3 way...I like it because it can be dash mounted giving you access to your level controls...the detents in the levels give you a more precise tuning...most are just varible so you can't get to the exact spot twice...like most gains on an amp...only quality pieces use the better tuning pots
Just installed this. Using it as a loc and xover off my stock headunit and an old *** BLAUPUNKT GTA2 Special MKII on 4 6w4p's and no tweets atm, lol. Definitely sounds better than the Scosche Wally World loc I took out, allowed me to bump up the gain a lil on the amp. Only problem is now I have engine whine and I have NEVER had engine whine in this car. Jumped the + and - for it right off the amp terminals, so going to try a dedicated ground and see if that helps. May end up grounding the RCA's.
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
  • Locked
Clearing out storage. $75 + shipping. Located in Carlsbad, CA. Pick up OK. Shipping weight is probably around 13 pounds. Slightly to deep to...
Louisiana_CRX
dem shoes......
Louisiana_CRX
Piney Hills of Louisiana
Bassin Buick
    May 16, 2024
    May 16, 2024
