F/S Kicker DX 1000.1
thedukey42
Kicker DX 1000.1
10/10 I installed it for a week and then decided I was done with car audio.
Kicker DX1000.1 1000 Watts RMS Mono Block DX Series amp [11DX1000.1]
SKU: 11DX1000.1-RS
RMS Wattage at 2 ohm x 1 Channel: 1000
RMS Wattage at 4 ohm x 1 Channel: 500
Peak Wattage at 2 ohm x 1 Channel: 2000
Stable down to: 2 Ohms
Active Crossover: 18dB/octave, variable 50-200Hz, low pass only
Bass Remote Included: Yes
Bass Remote Capable: Yes
Channels: Mono
Cooling Type: Heatsink
Design: Class A/B
Frequency Response: 25-200kHz, +0/-1dB
Input Sensitivity: high level 250mV-10V, low level 125mV-5V
KICKEQ Boost: variable to +12dB, centered @ 40Hz
Signal-to-Noise Ratio: >95dB, a-weighted, re: rated power
Subsonic Filter: (-18dB/octave, high-pass variable 10-30Hz)
$225 + Shipping
[br][/br]
[br][/br]
[br][/br]
614
thedukey42
thedukey42
Cleveland, Ohio
4bannger
    May 18, 2024
    May 18, 2024
