F/S Kicker DX 1000.1
thedukey42
Kicker DX 1000.1
10/10 I installed it for a week and then decided I was done with car audio.
Kicker DX1000.1 1000 Watts RMS Mono Block DX Series amp [11DX1000.1]
SKU: 11DX1000.1-RS
RMS Wattage at 2 ohm x 1 Channel: 1000
RMS Wattage at 4 ohm x 1 Channel: 500
Peak Wattage at 2 ohm x 1 Channel: 2000
Stable down to: 2 Ohms
Active Crossover: 18dB/octave, variable 50-200Hz, low pass only
Bass Remote Included: Yes
Bass Remote Capable: Yes
Channels: Mono
Cooling Type: Heatsink
Design: Class A/B
Frequency Response: 25-200kHz, +0/-1dB
Input Sensitivity: high level 250mV-10V, low level 125mV-5V
KICKEQ Boost: variable to +12dB, centered @ 40Hz
Signal-to-Noise Ratio: >95dB, a-weighted, re: rated power
Subsonic Filter: (-18dB/octave, high-pass variable 10-30Hz)
$225 + Shipping
[br][/br]
[br][/br]
[br][/br]
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
447
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
940
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
thedukey42
thedukey42
Cleveland, Ohio
4bannger
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
Latest topics
