Sold Sundown 100.4
treylittlefield
1. Product: ^^^^
2. Specs:
SPECIFICATIONS:
  • 4/3/2 Channel Bridgeable Class-AB Amplifier
  • MOSFET PWM Power Supply
  • Stable Into 4 Ohms Bridged or 2 Ohms Stereo Load
  • Variable Subsonic Filter
  • Independent 1/2 and 3/4 Channel High Pass Filter Variable
  • with x 10 Range Selectable Switch
  • Independent 1/2 and 3/4 Channel Low Pass Filter Variable
  • HPF/FULL/LPF Selectable Switch
  • Independent 1/2 and 3/4 Channel Electronic Crossover Slope Selectable
  • Switch with 12dB and 24dB Octave
  • Variable Input Level Control
  • Input Sensitivity : 200mV ~ 6V
  • Subsonic Filter : 10Hz ~ 500Hz
  • Signal Input and Line Out RCA Connectors
  • Multi-Way Protection circuitry (Thermal/Over Current/Speaker Short/Speaker DC protection)
  • Tested Voltage & THD: 14.4V & Less than 0.05% THD
  • Operating Voltage : DC10V~16V Power Input
  • Wired Remote Controller
  • MSRP $549 USD
----RMS power, 4 ohm stereo
100W x 4CH----RMS power, 2 ohm stereo
160W x 4CH----RMS power, 4 ohm bridged
320W x 2CHSignal to Noise Ratio>90dBLow pass frequency crossover
50Hz~5kHz (CH1&2)
50Hz~5KHz (CH3&4)
(50-500 with x10 switch)
Selectable 12 or 24 dB slope
High Pass Crossover
50Hz~5kHz (CH1&2)
50Hz~5kHz (CH3&4)
Variable Subsonic Filter10Hz to 500HzFrequency Response10Hz ~ 40KHz (+/-1dB)Bass Boost0~18dBVariable Bass-Boost Frequency Control35Hz to 120HzTHD@RMS Watts
3. Description/Condition: 7/10. has a dent where the line out is. came from the factory since it was b-stock.
4. Price: :$220 shipped
5. Pictures:
This image has been resized. Click this bar to view the full image. The original image is sized 799x597 and weights 25KB.
This image has been resized. Click this bar to view the full image. The original image is sized 799x597 and weights 33KB.
This image has been resized. Click this bar to view the full image. The original image is sized 799x597 and weights 27KB.
This image has been resized. Click this bar to view the full image. The original image is sized 799x597 and weights 26KB.
was this amp verified to work? id hate to buy an amp that was dropped and it not work.
also, why are you selling it?
if this amp is in working order i am interested in it. please PM with price to 71118. thanks! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
treylittlefield
treylittlefield
Sand Rock, AL
treylittlefield
