f/s Digital Designs C4a
select127
DD C4a 4channel amplifier
Great condition, minor wear nothing major and works flawless.
$240 shipped
C4a
Input Sensitivity
0.2V - 8V
Variable High Pass Filter
20 Hz - 5 kHz at 18dB
Variable Low Pass Filter
50 Hz - 5 kHz at 18dB
Clipping Display
LED
Tested Voltage
14.4V
Tested THD
1%
Model
C4a
Cont Power at 4 ohm
100W x 4ch
Cont Power at 2 ohm
150W x 4ch
Damping Factor
>250 @ 2 ohm
Cont Power at 1 ohm
175W x 4ch
Cont Power at 4 ohm Mono
300W x 2ch
Cont Power at 3 ohm Mono
350W x 2ch
Dynamic Power
400W x 2ch
Efficiency thru Output
>65%
Dimensions - mm
380 L x 235 W x 53.4 H
Dimensions - inches
14.96 L x 9.25 W x 2.1 H
Signal to Noise
92 dB
Shipping Weight
14 lb
select127
select127
Florida
select127
vegang
vegang
