F/S - Digital Designs 1000 Series 12" Dual 4 ohm Sub With DD Recommended Sized Box
NIHL8ION
RUN ur car NOT ur mouth !
Item(s) for Sale: - x1 DD 1012b D4 (Dual 4 ohm) 12" Sub With Custom 3/4" MDF Enclosure Built To The Full Size Box DD Recommends For This Sub (2.5 cu ft. net @ 38 hz)
Item(s) Description/Condition: - Sub is Like New, Just Barely Broken In, Never Had More Than 400w rms ran to it. Works & Looks Great. Box was JUST built Using High Quality 3/4" MDF to The Specs Recommended by Digital Designs (2.5 cu ft. net @ 38 hz). The Carpeting Job Is Not The Greatest, But It Looks Good. Very Solid, Nice Looking, & Good Sounding Enclosure Loaded With a Great Sub. Thanks for Looking.
Price: $180
Shipping and Miscellaneous Item Information: - Local Pickup Only (Very Massive & Heavy Overall To Ship...) I am In The Chicagoland Area, Illinois (South Burbs) & Will Meet Within Reason Of My Location (60561) To Demo / Show / Sell
Feedback link: http://www.caraudio.com/forums/itrader.php?u=1028333
im in rockford il. kind of interested. whats the rms on this?
SPECIFICATIONS
Cutout Diameter 11.13
FS 42.39 zhz
Magnet Weight 90 oz
Mounting Depth (in.) 5.19
Nominal Impedance D2.0 Ohm / D4.0 Ohm
Power Handling RMS/Peak 500/2000
QTS 0.818
QES 0.927
QMS 6.944
Series 1000b
Shipping Weight 17 lbs
Suspension Travel 66 mm
VAS 23.55
Voice Coil Diameter 2.0"
*** The 1000b series is a compact version of the 1500a Series. The slimmer profile allows depth challenged applications to benefit from high output and great thermal power handling. All moving parts are American made, with state-of-the-art technology.
The 1000b Series subs are hand built in our USA facility using parts developed with long term associations with our Amercan vendors. The voice coil uses the same high temperature grade wire as our 9500 Series. The suspension is optimized for 100-500 watt per driver system design yeilding a combination of extended low frequency response and high output. We use multiple glue types and multiple glue joints for all attachment points to give the long term durability DD subs are known for.
The 1000 Series can be optioned out with composite cones, composite dustcaps, Xstiff suspension and a multitude of logo options.
The 1000b Series shows that DD Audio can produce high-end, made in the USA subs competitive at price points with mass produced imports. There is no longer a need to compromise performance and quality when on a limited budget. Save the Planet, buy DD. ***
- I also have a nice Orion Amp that puts out 400 rms @ 2 ohms that matches up very nicely with this sub, I have it in my car hooked up so it can be heard in person. If you are interested I can make you a sweet deal on the whole package AND I will deliver it to you, let me know...
NIHL8ION
NIHL8ION
IlliNOISE
NIHL8ION
