Sold F/S Atomic AT-3000.1d 3200W RMS @ 1 ohm.....
ampjunkielikeme
450.00 shipped to the cont usa...firm...no trades.. paypal is preffered
this amp needs no introduction....Atomic AT-3000.1D
it works 100% ive had it hooked up for a couple hours beating the crap out of my 12's in my room...i am going to keep it hooked up until i sell it..the amp Pounds...lol
i had to replace a small capacitor, and a voltage regulator in the preamp section of the board..not a big deal.. all the rest of the board is in great condition.. its has never been worked on before i got it..
ive done vibration upgrades to the amp..ive added solder to all the "fets" legs. and epoxy the transformers/output chokes, and any capacitors that were loose...
cosmetics-- i would give it a 8 out of 10 . it has a couple scuffs and scratches..
function-- i would give it a 10 out of 10 . it works great
i will give you a 30 day warranty on the parts i installed..
* Digital mono block amplifier
* Dual MOS-FET power supplies
* Efficiency over 86%
* RMS power handling---1000w @ 4 ohms @14.4V
* RMS power handling---2000w @ 2 ohms @14.4V
* RMS power handling---3200w @ 1 ohms @14.4V
* Signal-to-noise ratio 85dB
* Phase shift 0-180 degree
* subsonic filter: 10-60Hz
* lowpass filter: 35-300Hz
* Input sensitivity: 200mV -6V
* 3 way protection: over voltage, speaker short & thermal overload
* Total harmonic distortion:
* Continuously variable 0 – 18dB Bass Boost
* Built - in variable 0 – 18dB per octave x’over
* Power Consumption
* Size: 23.25” x 10” x 2.20”
amp is sold with no warranty implied or expressed.(unless i give one). the amp has been bench/load tested , and it functions as it should...it will not arrive D.O.A.
nice *** amp iv always wanted one //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
i will sell it to you ....that is for sure...//content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
sexy sexy amp. how many Deka 9a31's would i need? i have 1 in my trunk now but i can get another for pretty cheap. i want to run to full 3000+ watts. I know it will sit on here for a while (no offense) but i will buy on the 1st of October if you still have it. PM all info you have for me
ampjunkielikeme
ampjunkielikeme
nash, tn
maximpakt
    Jun 20, 2026
    Jun 20, 2026
