F**k it....ill give it a try - T-line design, build and discussion (12 05xxx)
iamamp3pimp
Bass Heads Entertainment
heres the design that ive come up with so far....
port is 127 inches long, and has 70 square inches of area.
hmmm
cutsheet
top 36.25 x 14.0
bottom 36.25 x 14.0
Side 18.0 x 14.0
Side 23.75 x 14.0
Back 37.0 x 23.75
Front 37.0 x 23.75
Port 1 14.0 x 30.5
Port 1 14.0 x 30.5
Port 1 14.0 x 30.5
Port 2 5.0 x 14.0
angles - 4.5 (6) @ 45 degrees
specs
Length - 10.6 feet (127 inches approx)
70 square inches of port.
blah blah blah
this will be tested in an 03 mazda tribute with a xxx and a kicker comp 12
btu will be built for in home use.....
Discuss
About an hour ago there was a wasp in my house, buzzing around by the windom. I grabbed some newspaper, rolled it up, and swat him. He was still alive and moving so I just picked him up and threw it in the toilet. Well, about 5 minutes ago I had to poop and I forgot about the wasp. Im sitting down, pooping. A few turbs came out. Then, I felt something on my ***..kind of thought it was the water running down my cheeks from the splash of the turb. Well, it started to go towards my *******. I jumped up, and as I did so my cheeks smashed together traping the wasp inside my butt. Not a half a second after jumping up I felt the worse stinging in my life. The bastid shoved his thorn right into my soft, rose bud. Im screaming, jumping around and brushing off my anus. Its the worst pain ever. I got him off my ***, and the little ****er just flies up and into another room.
So now, im standing up at the computer. Debating if I should go get my brother so he can put some creme on my swollen rectum. It sucks.
About an hour ago there was a wasp in my house, buzzing around by the windom. I grabbed some newspaper, rolled it up, and swat him. He was still alive and moving so I just picked him up and threw it in the toilet. Well, about 5 minutes ago I had to poop and I forgot about the wasp. Im sitting down, pooping. A few turbs came out. Then, I felt something on my ***..kind of thought it was the water running down my cheeks from the splash of the turb. Well, it started to go towards my *******. I jumped up, and as I did so my cheeks smashed together traping the wasp inside my butt. Not a half a second after jumping up I felt the worse stinging in my life. The bastid shoved his thorn right into my soft, rose bud. Im screaming, jumping around and brushing off my anus. Its the worst pain ever. I got him off my ***, and the little ****er just flies up and into another room.So now, im standing up at the computer. Debating if I should go get my brother so he can put some creme on my swollen rectum. It sucks.
wasp: 1
you: 0
lmfao and disgusted at the same time:laugh: //content.invisioncic.com/y282845/emoticons/sick.gif.b1847c8dabbfeeddbcf1a78052249e10.gif
Thread jacker ^^
why that wasted airspace just to the left of the woofer?
is it just me getting confused?
Because the port length had to be a certain size and he wanted the box to be xx inches wide and xx inches tall.
He designed it to fit in a certain spot, and to be square, versus desiging the box around very strict port size, and having some odd shape in the end...so this way is just easier to design and do the math right.
Just modeled this in mathcad with the comp 12 and it looks pretty good, solid 4db gain over sealed from 80hz down to 30hz tapering off towards 20hz, should sound pretty impressive.
iamamp3pimp
iamamp3pimp
Tampa FL
iamamp3pimp
