camdogg4570 10+ year member
Ok, so i have a 1997 f-150 and im putting in a 130 amp altenator. I'm planning to do the Big 3 with 4 gauge wire also, but I've run into a small problem...... There are two wires that run from my altenator (I do not know why there are two wires, if you have any idea please let me know) and they run to a Maxi Fuse then to the battery +. Basically, the Maxi Fuse is what stands in my way to doing the Big 3. I don't know where to get a new fuse or what I should do to run the wires and keep the fuse. It is a 170amp fuse, and I don't think i can "reuse" the old Maxi Fuse because the connections seem to be to small for 4 gauge wire. If you have any idea of what I could or should do, PLEASE let me know! I need help ASAP. Thanks.
