Extra Wires on harness?
  • 4
crazyone
Canada
I bought a Pioneer 7900bt and the appropriate wiring harness for my car.
I have several wires left over that I'm not sure about,
would anyone know which to connect these to ?
Blue System Remote Control to ?
Yellow Black Mute Wire to ?
2 black ground wires from Non Pioneer Wire harness to ?
1 orange black ground wire from Non Pioneer Wire harness to ?
1 long black ground wire from Pioneer harness to a ground point under a bolt,
Red Accessory wire To red 12 v ignition wire (i dont have any accessories to use)
Orange ILL to orange illumination wire
Yellow Battery Terminal Wire to Yellow 12v wire
grey to grey x2
green to green x2
white to white x2
purple to purple x2
I bought a Pioneer 7900bt and the appropriate wiring harness for my car.I have several wires left over that I'm not sure about,
grey to grey x2
green to green x2
white to white x2
purple to purple x2
I'm a little confused by your post which wires are not hooked up to anything? And what kind of car do you have?
mute wire is for cell phones or something like that. you probably dont need it. the dimmer ground wire is used if you connected the dimmer/illumination wire. just connect that wire to a ground. I dont know about the other 2 ground wires, but if its ground wires, GROUND IT!
The manual says
If you use an equipment with Mute function, wire this lead (yellow/black) to the Audio Mute lead on that equipment, If not, keep the audio mute lead free of any connections.
Its a cell phone, how do u wire it to that 'equipment' ?
The mute wire is for old school hands free kits. You can not hook to your cell phone. This has been replaced by bluetooth which you also will not need this wire for.
The ground dimmer wire, just tape off.
The blue white from the pioneer you may need if you have a factory amp. Is there a blue white on the factory harness? If so just connect them together.
The red is your accessory power, connect to red on factory harness.
Yellow is constant power, again match up to factory harness.
Gray, white, purple, and green are speaker wires.
the two grounds from your ford harness are a radio ground and an amp ground. Just ground them both even if you dont have a factory amp, it wont hurt anything. The harnesses are mass produced and will not use every wire for every car.
If I was in your situation, I would experiment with the wring for a day or two. If that didn't work, I would purchase an external amplifier. Run...
984
I didn't read the article, but with those GM Bose systems; either fix what needs fixing, or rip out the entire thing and start from scratch with...
Try placing the subs in the front seat, to see if the issue persists. Just for diagnostic purposes. It may be wiring, but the distortion may be...
947
crazyone
crazyone
Canada
mokedaddy
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
