Extra Run of 0 Gauge?
nicker10
I was thinking of upgrading to 5000 rms..and most amps that have that much power have 2 sets of power and ground wires..when adding a second run do I have to go from the front to back with the power wire or could I just add a second run off the batteries in the trunk?
With 5kw I'd definitely recommend two runs from front to back...unless you like the smell of electrical fires.
i am gunna be running about 4.5k watts should i run 2 power and 1 ground? or is it safe the way i got it with 1 ground 1 power front to back??
With that much power 1 of each is not going to be enough. You should do two of each. You amp has two terminals for power and ground right?
I am running a RD D9 at .8ohms roughly 5k watts and 2 runs of klmx 1/0 power and 2 runs of klmx 1/0 ground front to back and dropping .75-1 volt so i would do 3 power and 3 ground runs or even better 4 of each
holy shit!@!!!!!!!!!!!!!!!! i am not gunna run all that shit....lol i might just might run another power ....lol
2-3 runs is prime for the amperage that will be pulled.
and doing 2-3 runs of + and only 1 run on - is a bad idea.
it'd be like running a single 1/0 run for + and a single 8gauge run for -..
bottleneck.
yeah do both....
nicker10
nicker10
Indiana
schackel
