Exposing circuits in install
ashren315
I have 2 old school RF amps (a 600a4 and and 800a4) that I'm about to use in an install. Both amps will be in an amp rack that will have a edge lit lexan window covering them. If I were to turn these amps upside down, remove the bottom covers off them so the circuits would show though the amp rack windows, do you guys think I would have any overheating issues? My plan is to have two small fans on each in a push pull configuration to flow air over them.
nope your good.
just make sure you use them fans.
cross flow and your good.
if your going to use the plexy right on the bottoms of the amps, i would drill some holes in it.
if the plexy is spaced off the amp, then you will be fine.
ashren315
ashren315
Canton, MS
ashren315
