Explain xover settings on orion 2500D
Colt9699
Rockstar
like the title says I would like to have a better understanding of the xover on a 2500d.
the switches are
full/12/24
dial from 30hz ~250hz
switch off/hp
dial 10hz ~ 150hz
dial Itelli Q
could anyone explain exactly how i turn on subsonic filter, and anything else about how this operates?
I've subscribed because I'd like to know a little more about this as well.
I guess maybe I'll give DEI a call since I'm not getting too much love here.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
I'll post whatever I find out.
like the title says I would like to have a better understanding of the xover on a 2500d.the switches are
full/12/24
This is low pass crossover slope selection. Unless you're a hard core SQ listener 12/24 won't make much difference. You just don't want it on full. Generally, the higher the better.
Low pass crossover frequency selector -- generally somewhere around 80 hz
switch off/hp
This is your subsonic filter switch.
dial 10hz ~ 150hz
this is your subsonic filter frequency selector. If you have a ported enclosure you'd want the switch set to HP and the dial set somewhere around the tuning frequency.
If you have a sealed enclosure you can either leave the switch off, or turn it on (HP) and set the dial around 20 hz.
dial Itelli Q
just looks like a hyped up bass boost to me. I wouldn't mess with it - leave it at zero.
http://www.directeddealers.com/manuals/og/orion/47400_Orion_600D_Owners_Manual.pdf
Colt9699
Rockstar
Colt9699
Erie Pa
Colt9699
