The Camry
Hey, I Try.
Amplifier Gain Controls
After reading that. My knowledge of gains are..totally different...Yet im still confused a bit.
You have a 100rms x 1 channel amp. your gains are at min. which would be all the way counter clockwise and for arguments sake. Lets say that is 10 volts and all the way clockwise is 1 volt.
and your head unit is 5 volt pre outs, and again for arguments sake. your headunit will give you a true 5 volts at 95% vol before clipping.(which i would assume clipping would just be any voltage above 5 volts ??)
Its this part that im a little lost on.
Contrary to popular belief, an amplifiers gain control does not determine the maximum power that an amplifier can produce. As long as the preamp/drive signal has sufficient level, the amplifier will produce its maximum power output level."
If your gains are set at min. how does that affect power output? Are you only getting 15ish rms out of your 100?
