Explain alternator/ battery charging system to me please?
This is a good question, and one I've asked myself a lot. I'm of the opinion that as long as the alternator has the necessary capacity high priced and/or add'l batteries aren't that beneficial. I think a good quality/healthy regular lead acid battery will do 99% of what an expensive one will do.
(On the other hand, if the alt is under-sized, a big battery might cover up the day-to-day issues, but the alt's going to fail eventually, then the quality of the battery won't really matter -- it's dying regardless).
I believe the mfg's claim their batteries are lower resistance than a typical battery - requiring a bit less energy from the alt to maintain their charge.
I'm guessing they also have a little more available power in that 14+ to 12.6v (float charge) range.
Maybe a $300 battery believer can shed some light on this.
How exactly does the relationship of the alternator to the battery work? i understand that if you get a HO alternator. Itll charge the battery faster and you wont have to worry about voltage drop but why does having a better battery help? what does a high end battery do for you?
the alt. makes the power, the batter holds that power.
when your alt. cant keep up then it pull power from battery. and thats a bad cycle as the alt. is always trying to keep the battery charges.
the first upgrade should be a alt. ( remember, alt. MAKES THE POWER ) then you can get a better battery.
a high end battery give you more capacity,, lower resistance ( meaning it will take and give power faster ) and being an amg ( glass mat type ) it can be installed upside down if you like....
now you dont have to buy an audio battery . many like the Duracell amp battery and there are a few others. these are like deep cycle amg type.
This is a good question, and one I've asked myself a lot. I'm of the opinion that as long as the alternator has the necessary capacity high priced and/or add'l batteries aren't that beneficial. I think a good quality/healthy regular lead acid battery will do 99% of what an expensive one will do.(On the other hand, if the alt is under-sized, a big battery might cover up the day-to-day issues, but the alt's going to fail eventually, then the quality of the battery won't really matter -- it's dying regardless).
N2...this the same n2 that helps out on Yahoo answers? ! Lol
(Sorry, off topic)
The Camry
Hey, I Try.
The Camry
Western Oregon
n2audio
