Well, since are changing subjects....
I went to a local audio shop the other day...just to look. The guy asked what amp Im running. I say Sundown 3000D. He looks confused and then asked to take a look at it, so I show him. I tell him its 3000w @ 1 ohm. Then he said "Yeah if lightning strikes it!"
Apparently a retard. Retards can run business's too... just look at me!
LOL. He has probably never heard of or had experience with these amps so as it is unknown to him he degrades it and writes it off as junk. Most people who run stereo shops seem like used car salesmen to me... you get a totally different story about products from one place to the next.
The only mechanical difference in the way it would be working that I can think of, and I am not really an SQ guy, or a physicist (sp?) nor is my IQ over 130, but I know how the amps work, somewhat anyway, as I do work on them every day, is the difference between high voltage going out on the speaker wire vs high current. At regular listening levels (not balls to the walls) with a 4 ohm load you would be getting something like 60-80 volts AC and 15-20 amps AC being sent to and from the subwoofer by the amp (around 900 watts or more), whereas with 1 ohm it would be more like 28.2VAC and 28.2AMPS ( around 800 watts). Maybe it's easier for the subwoofer to be controlled by the higher voltage than by the higher current. Therefore making it sound "crisper".
Again I probably shouldn't even get involved in these things but I couldn't resist at least reading it and posting something.
Also the proper way to read the output to your subwoofer while it is playing tones, put a AC Clamp meter on 1 of the 2 speaker leads (either the + or -, do not put the clamp on both wires) then use another meter set to AC Volts and attach the leads to your amps + and - wires (1 on the + and 1 on the -). Put a tone in crank up the volume, then write down the readings from the meters and use these formulas:
Power in Watts = Voltage x Current
If you got 60volts AC and 15 amps AC then you have 900 watts
Then divide the two numbers to get your actual impedance at that freq:
60/15 = 4 ohms
28.2/28.2 = 1 ohm
The "dipping" of the rail voltage of the amps power supply could have something to do with it not sounding near as good at 1 ohm as it did at 4 ohms. Again this all goes back to control over the subwoofer motor.
I think you will probably find (if you go buy the meters and check it) that the SAZ-3000D will do WAY more watts at 4 ohms than 800....
And as far as some of the comments here... You have to understand something about internet forums. There are a lot of really dumb people here, and really smart people here.... The dumb ones will mislead you, the smart ones will toy with your head, as they enjoy "playing" with you like a child. I have a diverse group of friends, some with sky-high IQ's and some with double digit IQ's (low) and I have found this to be true at least in my experience with it, as IQ goes up common sense goes down, kinda like a see-saw (sp?) effect. And vice-verse, as IQ goes down common sense can actually go up till you reach a point that you are mentally retarded and common sense and "smarts" don't exist, everything seems the same to you and you only know what you see in front of you. Anyway I am rambling, but the point is, don't let them get to you. You are doing the right thing by asking questions and I think there have been some good attempts here at answering them, and my own personal explanation would have to be the high-voltage involved is having better control over the speaker, giving you tighter crisper bass response.
