experimenting help
have you tryed the subs free air, at low power to see if the same thing happens.
if the same thing happens you may have a bad amp, internaly the push pull configuration is not balanced and it pull to one side intead being at zero.
test it out before you kill your subs.
when the subs were in smalled sealed boxes they moved out, although not much. i was gonna try different things to see what kinda increase i can get from them. i have like 12 boards of mdf and a gutted neon so i figured i'd play a lil bit.
considering the music is being played through the coil of the sub this should be observed...
A subwoofer is a fixed magnet with a coil in the middle of it.
The coil is supplied with power from the amp. Creating a Electro-magnetic field
The "Music" is a AC sine wave. Meaning that the polarity on the coil changes with every 1/2 cycle at any given freq.
If your sub only moves one way then you are giving it DC.
So end result is how do you figure it only moves in or out? If you are hearing sound then it is moving both ways. Maybe you are just seeing alot more of the excursion (sp?)
If you have a multi meter you can set it to DC Volts and parallel it to your sub. You should read 0 V dc, (or within a few hundred mV anyway.) If you hear music AND have a few volts DC then there is a problem with your amp, and from a electro-mechanical stand point it would be the equivilent of a AC sine wave riding a elivated DC signal. All in theroy of coarse. J/L
if the sub is puting out sound but is pulling the sub in. its posible that the sub instead of playing in a push pull from zero is doing it from some thing like -3v or some thing of that sort thats why the sub pulls in and still plays music. if it was only getting a dc signal it would just pull to one side ither up or down. so if it pulls in but not all the way. the amp is out of balance internaly the dc offset is not set to 0 were it should be.
So arnt me and you saying the same thing?
slow_hoe2001
slow_hoe2001
hartsville tn
DarkFox
BP1Fanatic
BP1Fanatic
