Experience with Mustang 460 systems???
ColterDC
I have a 96 GT with the stock mach 460 system and an aftermarket Pioneer deck with a small amp running two 10's in the trunk.
A few nights ago I had the headlights, heater and stereo on and was getting huge voltage drops. Eventually I had to turn the stereo down for fear of the car dying.
The car has a 130amp alt and the big 3 is done. Normally during the day (no light or heater on) the car runs fine and the stereo playing at full volume doesn't effect anything.
Does anybody know what % of the car's stock voltage is being used before the addition of any aftermarket stereo equipment?
I'm wondering if the fairly small amp (400 RMS watts pushing to 10's) is putting the car over it's voltage limit and I need a stronger alt, or if my current alt is dying or what the hell is going on.
I'm also debating ripping out the 460 equipment and just getting a 4 channel amp to run those speakers.
Thanks,
Yeah, I will double check them all again before I go out and spend even more money on this car.
But I have read that Ford doesn't leave alot of "extra" room in their mustangs for additional aftermarket electronics. No luck finding out how much of the stock voltage is already being used, but you wouldn't think my tiny 400 rms watt amp would kill it, even with the lights and heater on. But who knows with that 460 system taking up alot of voltage.
Think I need a new battery, but I don't think that would cause my problem and before I go spending several hundred on a H/O alt, I'd like to rule everything else out.
Man, cars are frustrating sometimes.
it might be your front battery i would go get it load tested and go to DB electric.com its something like that they aint the best alts in the world but they work pretty dam good and are a good price
your sig says 1 MTX 12 inch sub......hmmmmmm
Haven't bothered to update it. Especially since it hasn't been working so well.
Plus, my plan is to put two 15's and a bigger amp in there, if I can get my problem figured out.
hahaha good luck with that one i only could get 1 15 in my trunk and that was up firing and the boxed used the whole trunk and the spare tire well
I guess since I was planning on doing a sealed box (Plenty of room for 3 cu ft) and because I was thinking I wouldnt need any extra batteries in the trunk, that I'd have enough room.
Come to think of it, when I swapped out the one 12 that was back there for the two 10's, I also changed amps and had to move the ground wire. I'll have to check that again.
If my battery is dying or has a bad cell, would that cause a voltage drop problem? I thought that once the car was running that it was all on the alt?
ColterDC
ColterDC
SLC
ColterDC
vegang
vegang
