Excursion System Rebuild
Kingsuv
Now that I have this going a bit, I thought I would bring it over here to share.
Here is a link to the good ol days with it. It's been without a system since about late 07.
Full Excursion - Kingsuv's On Going Build - The Forum
1st set of the 30 some odd sets I have to make. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
A large part of this ongoing build will be redoing stuff that was done in a rush the first time. Most of what you see ( or don't //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif ) was done mostly just before a comp or a car show, so there is way more rats nest then any one car should have. Now that I have time to go through it, I will post up whats being done like it should of the 1st time.
Don't ask for before pics, I didn't take any and I'm sure as hell ain't going to post any.
Today's project was to redo the A pillar gauges. It wasn't some much as an issue as it was for convenience and looks. The wire was scraps and all the connectors were crimped. Now it's pimp. Too bad the only time you will see it is here in pics :lol:
Here is some of what is going in.
And then the control center.
It's a tight fit. And sure to be fun to wire up.
I am using 3 HR-4125's with a total 16 channels of processing. I used 3 HF-1000.1's to mock up where I want them to go
Then you can't forget about the madness.
I haven't decided if I will use 2 Inferno 8.1's or 4 HF-2500.1's yet. Or maybe I will use more
Started off needing a false floor for the center console. The brain and 2 processors will be housed in there as well as the Sirius and the ipod control.
Also picked up A new distro block for all my addons.
And have been working on these for days now. I'm about half done. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Added a little more bling for the center console.
Started marking all my channels so I can lay them in the truck tomorrow.
Decided to do the PXA H510 For the rear processor. I have 3 of them so I might as well use one //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Besides, Have a sweet spot to add the controller in the rear of the center console
Also picked up a lumber rack for the shop. Now that it has wheels I will move it over to the shop
Have just about all the power side of the control worked out. If all goes well I will have all the RCA's and AI-net, and Speaker wire ran tomorrow.
Then I will pull it all out and PIMP it out with some brand new Second Skin Damplifier Pro Black next week.
Oh and I have some stuff sitting around here thanks to Scottie at XS power.
I needed a solid way to bolt everything down. Sheetmetal screws **** when you have one of these //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
It's like having pop rivets with threads in the middle
ANT over at Second Skin hooked me up proper!
He said I wasn't busy enough so he sent me more work to do
The UPS man hasn't been too happy with me lately. He asked if I had any packages coming in that wasn't over 50 lbs. I said just wait till my sub order comes in
Hard to tell in the pics, but the new black is the ****!
Worked in between the rain drops
Added a layer of Luxury Liner. This stuff is killer //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Started the 2nd layer of wiring today.
Kingsuv
Kingsuv
Sacramento, CA
Brian_smith06
vegang
vegang
