Hello, your looking at a carputer setup, never used, only hooked the touchscreen up to a portable dvd player to check it out!
This unit has capability for Wi-Fi, GPS, Bluetooth, etc.. And will controll your whole audio system from the screen!!
10.4in touchscreen- TFT-LCD monitor- comes w all wires, and software. Great picture!
Along with this is a MSI K9MM-V mother board.
CPU
• Supports 64-bit AMD® Athlon™ 64 / Athlon™ 64FX /Athlon 64 X2 processor (Socket AM2) (FSB Speed up to 800 MHz/ 1600 MT/s)
• Supports Sempron CPU: 3000+, 3200+, 3400+, 3500+, 3600+, 3800+
• Supports Athlon 64 CPU: 3500+, 3800+
• Supports Athlon 64 X2 CPU: 3800+, 4000+, 4200, 4400+, 4600+, 4800+, 5000+, 5200+
Chipset
•VIA® K8M800 Chipset
- HyperTransport connection to AMD Next Generation of CPU; FSB Speed up to 800 MHz (1600 MT/s)
- 8 or 16 bit control/address. data transfer both directions
- 800/600/400/200 MHz "Double Data Rate" operation both direction
- AGP v3.0 compliant with 8X transfer mode
- On-board Graphics shared up to 64MB
•VIA® VT8237R Plus Chipset
- Ultra DMA 66/100/133 master mode EIDE controller
- Integrated dual channel native Serial ATA/RAID controller that will supply 150MB/s and support RAID 0, RAID 1
- ACPI & PC2001 compliant enhanced power management
- Supports 8 USB2.0 ports. (Rear x4 / Front x4)
Main Memory
• Supports dual channel DDR2 533/667/800, using two 240-pin DDR2 DIMMs.
• Supports the memory size up to 2GB
• Supports 1.8v DDR2 SDRAM DIMM
Due to the High Performance Memory design, motherboards or system configurations may or may not operate smoothly at the JEDEC (Joint Electron Device Engineering Council) standard settings (BIOS Default on the motherboard) such as DDR2 voltage, memory speeds and memory timing. Please confirm and adjust your memory setting in the BIOS accordingly for better system stability.
Example: Kingston HyperX DDR2-800 PC-6400 operates at 2.0V, 4-4-4-12.
For more information about specification of high performance memory modules, please check with your Memory Manufactures for more details.
Slots
• One AGP (Accelerated Graphics Port) 1.5V 4x/8x slot
• Three 32-bit Master PCI Bus slots
• Support 3.3V/5V PCI bus Interface
On-Board IDE/SATA
• One IDE controllers on the VIA 8237R chipset provides IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA133/100/66 operation modes.
- Can connect up to 2 IDE devices
• VIA RAID supports 2 SATA ports (SATA1-2). Transfer rate is up to 150MB/s.
• VIA RAID (Software)
- Supports up to 2 SATA
- RAID 0 or 1 is supported
BIOS
• The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and expansion cards of the board automatically.
• The mainboard provides a Desktop Management Interface (DMI) function which records your mainboard specifications.
• Supports boot from LAN, USB Device 1.1 & 2.0 and SATA HDD
Audio
• Chip integrated by Realtek ALC655
- Compliance with AC97' v2.3 spec
- Compliant with PC2001 audio performance requirement
LAN
• Supports singlel LAN jack
- Single LAN supports 10/100 Fast Ethernet by Realtek 8201CL
On-Board Peripherals
- 1 floppy port supports 1 FDD with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes
- 2 serial port
- 1 parallel port supports SPP/EPP/ECP mode
- 1 audio jack (5-in-1), coaxial/fibre SPDIF out
- 8 USB 2.0 ports (Rear x 4 / Front x 4)
- 1 RJ45 LAN jack
- 1 VGA Port
- 1 CD-in pinheader
- 1 IrDA pinheader
Dimension
9.55 in (L) x 8.1 in(W) Micro-ATX Form Factor
**And a Western Digital WD1600JB Re-Certified hard drive **
160 GB formatted capacity
UDMA/100
7200 RPM spindle speed
8 MB buffer
8.9 ms average seek time
4.20 ms average latency
E-IDE/ATAPI interface
3.5-inch form factor
Asking 550 shipped, or make me an offer!! Will trade for HU w/ 4-5V preouts and USB
CPU
Chipset
Main Memory
Slots
On-Board IDE/SATA
BIOS
Audio
LAN
- 2 serial port
- 1 RJ45 LAN jack
- 1 VGA Port
- 1 CD-in pinheader
- 1 IrDA pinheader
Dimension
UDMA/100
8 MB buffer
