EQ on Alpine CDA-9884
KaMiKaZi_t0M
Alright, I can't figure this out and it's REALLY bugging me. I don't feel like my setup has enough mid, and I don't know where to change that. I've found settings to adjust treble and bass, and subs, and EVERYTHING under the sun,but no Equalizer. Can someone inform me on HOW to get to this **** thing.
Thanks,
Tom
They use the same manual for a bunch of their Headunits but make notes of which features are available on which headunits..
You can get a cheap EQ that you can install in a 1/2 din or anywhere else convenient..
Mids are not easy. Sure you can boost them with an eq but will your speaker be able to put it out is the question..
Yeah I'm seeing the iPod stuff. Only problem is a have a Zune, so it doesn't help me at all. My speakers are all aftermarket so they should be able to put out. 6.5 Audiobahns in doors, 6x9 kenwoods in shelf, polk 3.5's. The EQ sounds like a pretty good idea. I wish the 9887 wasn't an extra 100 bucks.
Tom
With after market amps on your system I have been wondering what is the real need to have EQ's on the HU? I was always under the impression that yeah maybe you need to cut a little somewhere, but messing with the HU EQ is not that great of an option.
I have an Alpine 9813 right now and do not even have the EQ or MX enabled, and just set the HP/LP filters and Bass Boost from the amps themselves.
I have been looking into the DVA 9861, but read it doesnt have all the EQ tuning like the 9813/15 does. Can someone convince me why you would want to have EQ tuning in the HU when you use an amp?
Thanks,
Tom
I am afraid the part you missed about unlocking the 2008 9884's 6 channel time correction, 5 band graphic and 7 band parametric equalizers is the required Alpine PXA-H100 IMPRINT sound processor (this thing is loaded with options for your HU) which in turn requires the Alpine KTX-H100 IMPRINT tuning kit. March availability for both according to Alpine. This also applies to the 9886 as well.http://www.alpine-usa.com/US-en/company/pr/pr.php?prid=177&year=2008
Tom
The 9887 requires the KTX-100EQ IMPRINT tuning kit to unlock all of its goodies. Suggested retail of around $250 or you can rent it at Crutchfield for $50. So as you can see the cost just keeps on going. //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
KaMiKaZi_t0M
KaMiKaZi_t0M
Connecticut
Habanero
vegang
vegang
