EQ help needed
bsean63
Undead Revolution
im confused on how to wire the EQ int the system.. do i just run RCAs from the front output on the EQ to the Aura amp, and RCAs from the sub output on the EQ to the Alpine amp??
just get your main rca form the HU and plug in the main as far as powering it . coonect the wires and tune it up then from each out plug to according amp
could you plz break it down a bit more for me, thaks for the help btw
Use your front rca's from the HU and run them to the input on the EQ. You won't need to use the rear and sub out on the HU. Then from the EQ you run your front,rear, and sub outs to your amps. Make sure the high pass is turned off if you have that option on your HU.
bsean63
Undead Revolution
bsean63
ohio
WALKS UP
vegang
vegang
