Engine whine solution?
  • 2
elroyboy
Hey all, first post here. I installed system in 04 bmw 325ci that included Kenwood kdx head unit, 5 channel amp, and powered sub. I have a whine that goes along with engine rpm. I think I have narrowed it down to the powered sub. When I unhook it the whine goes away. I have tried different ground places but to no avail. Any help appreciated.
Buy a pair of RCA ground loop isolators locally from an electronit store or Amazon and see if that helps, it solved my issue.
The problem could be the rcas are run alongside the power wire, which makes sense when you unplug the power the whine goes away
Then I don't really seen the need to run a ground directly from the alt, but given your situation, it can't hurt.
24
Nice looking RCAs. Most vehicles these days have quite a bit of wiring to go back to the vehicle lighting ect that run along the bottom door...
15
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
I would run another ground wire to cleaned off metal. Sometimes there is a Metal Bracket under the dash that generally work well. You can try...
Sounds like a ground loop, especially with the hokey ground. I'd ground to the body, do the big three. Run a ground from the radio to the amp's...
elroyboy
elroyboy
kentucky
elroyboy
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
