Engine Noise???
Run a temp ground wire from all of your amps to the front battery NEG- post. Make sure it is a decent sized wire, at least as big as your POS+ wire. See if the noise is still there. You might have bad grounds in the car. Running a dedicated ground might solve the issue.
We are gonna try tonite
if you have more than 1 set of rca cables, they need to be attached together all the way back to the amps. if they become seperated it can create a ground loop. the futher apart they are the larger the ground loop and the more noise. not saying this is the case but, you may check it.
teenapp
teenapp
Virginia
pawn man
