engine noise problem, what did i miss
bumpncarstereo
4X4
ok i have tried unpluging the antenna (i think, i will try it again)
i took an rca to 3.5mm jack and pluged my ipod directly to the amp. and the noise was gone.
i ran a set of rca's unrouted from the HU to the amp and there was still the noise. louder even
i un soldered the wires and twisted them together, as if they were in a pigtail connector, and it was still there.
hu the problem maybe? i hope not.
if i can find some wire i will run a ground to the battery in the trunk/ where the amps are grounded
Take a 14 or 12 guage wire to ground the head unit to the car chassis...Stay away for the ground in the harness. Make sure it is right to bare metal or chassis bolt.
bumpncarstereo
4X4
bumpncarstereo
Rochester NY
GCAdidas13
