Engine Noise Help Please
americanskiff
Well, I thought all was well. Install completed about 2 weeks ago, everything sounded good. Yesterday took the boat out fishing and for some reason now I have some nasty engine noise. But, when I turn left the noise goes away. Thinking I hit a bump and nocked something loose. I checked all the wires and everything looks and feels good. With the engine running I wigggled all the wires. THe culprit is the HU. I rewired it and turned it on with the engine running anf reved it up and all sounded great. Put it in the dash and inserted the dash bezel and the sound came back. It may be the metal frame the HU sits in or something. ANyone have any suggestions? I did a search and found nothing simular to this..Only thing I can think of is another ground for the HU. Its wired into the factory connectors ground. Thanks for the help.....
can you be abit more specific? Sorry im new to this:) I know the ground from the amp is good. Its 4ga wire to a very bare metal area. How would I need to ground the HU other then using the factory ground in the factory connector?
americanskiff
americanskiff
Jax,FL
americanskiff
Mike Mccabe
